Ga door naar hoofdinhoud
Computers die over het algemeen geen geïntegreerd scherm hebben, en die bedoeld zijn om te blijven staan.
2133 Vragen Bekijk alle
RAM incompatibility problem with motherboard
Hello,
I just build a PC, here are my specs:
MSI X399 Gaming Pro Carbon Ac
AMD Ryzen Threadripper 1920X Box
G.Skill TridentZ RGB 16GB DDR4-3200MHz (F4-3200C16D-16GTZR)
Gigabyte GeForce GTX 1070 Ti 8GB (GV-N107TGAMING-8GD)
CoolerMaster MasterCase H500P Mesh
Samsung 970NVMe M.2 250gb
NZXT Kraken x62
So, I build this PC and when I boot up I enter bios and I see that everything was ok, the pc was reading everything. When I entered the windows 10 usb to install windows, I received from my motherboard an error 61 and I read in the book that error 61 means NVRAM initialization and the pc freezes on black screen. I read on MSI website that my RAM sticks are incompatible with my motherboard, but in BIOS it reads the RAM sticks perfectly. Does anyone knows what the problem is?
Thank you.
Is dit een goede vraag?
1 Opmerking
So where are u getting error 61, at this point is there any signal to the monitor or can you enter the bios if you were able to install windows without getting any errors it may not be a compatibility issue but rather a bad ram stick let me know some more info and ill see if I can help
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I don’t know what the problem was, but I updated bios and then reset it to default setting and somehow it worked. Now I also overclocked ram and everything works perfectly!! Thank you very much for the respond!
Was dit antwoord nuttig?
Het nuttigste antwoord
Just because it can see the RAM does not mean it is the correct RAM.
Look on this chart for compatible RAM for your board:
https://www.msi.com/Motherboard/support/...
Score 3
1 Opmerking:
Ryzen and threadripper are way more sensitive than the older AMD chips.
door
Voeg je antwoord toe
Savvas Giannoukas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 360
