Ga door naar hoofdinhoud
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Vragen Bekijk alle
Battery connector detached from motherboard... any fix possible?
Newish Macbook Air, got water in it… I removed battery to try to save it… put it back in to test (didn’t screw batt down) and when I took the bottom cover back off battery slipped and tore connector off logic board. Am I completely screwed? Logic board may be short anyway as even w some alcohol clean up and the power coming back to the fan I didn’t get it to start… still now I have a NEW problem… I read an earlier answer which didn’t sound very helpful to me as an amateur but was looking for other help…
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It depends on the extent of the damage, hard to tell without seeing what the conditions are, however if the solder pads are still present on the logic board surface the connector can be resoldered back in place. If on the contrary pads have been teared off taking away traces it’s gonna be a challenging fix, if possible at all.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
The pins on the logic board are still all intact and I can line them up w the slots in the connector (the one that should be in the board). I can also, if I keep my finger on the connector, slide in the connector from the battery. Just not sure if it's "in tact" thanks for your help. BTW, I can't really test it as I can't get the machine to boot yet... it is getting power to the fan from. I've tried SMC reset, PRAM reset and I did get the keyboard backlit once. I've removed the SSD and found a bit of corroision/fluff on some connectors so I've cleaned that. I am going to try to remove logic board to get a look underneath but that's a bigger job. Most of all I am trying to figure out if the fact that if the pins on the logic board bit the connector if it might still make the connections.
door
Well, you don't need the battery plugged to troubleshoot your Mac, most important thing is to get it back running first and once that's done, since you seem to have all pads in place soldering back the connector would be a relatively easy task. Unless you did it before, take a look and go through this excellent guide for taking care of water damage:
MacBook water damage - The definitive guide
door
Thanks -- I've done the water damage stuff...but will re-read that guide anyway. I actually took the system board out (I screwed up on the speaker connector... complete amateur, me... it lifted "up" not out... so that's another solder job). There wasn't any water in there but I could see some marks... I cleaned those w denatured alcohol... let it set and then re-assembled and tested... fan comes on... I did the SMC re-set as well for good measure... but doesn't boot up. I am going to try to test the drive card in another Macbook Air to see if it will boot and then focus on that if it's not bootable. I will send the machine out for soldering if I can get it to re-boot.... or maybe anyway... it's less than 2 years old. [I should also note that it's actually not my machine... it's my daughter's but I bought it for her!]
door
Having fan spinning is a start, liquid damage sometimes may be devastating and render board fixing impossible or too expensive. You can try plugging the Macbook to an external monitor/tv to understand whether it's a no boot or no image issue. In case you got an image you can plug back the screen and shine a light to it to see if it's just a backlight fault. However, it seems like you'll need to hand it over for component level repair for one reason or another.
door
The people on here are not the wisest sometimes, so here’s the truth. YES it is fixable by someone who does logic board repair. Even if pads were ripped it’s still easily fixable. Send it to someone who can repair logic boards such as Louis Rossmann, TCRS Circuit, or even our business at Device Pro Solutions. We all have the tools and skills to fix it easily
Score -1
2 opmerkingen:
Thanks Brady8812 -- if the pins (is that what you mean by pads?) are intact and I can make the "socket" piece connect w them, is it certain it will still need repair? For repair, any sense of cost IF the pins on the logic board are all still in tact?
I have to see if I can get it to at least boot up on hard wired power. Are there websites for TCRS and Device Pro? Thanks.
door
Yeah, really hard to understand how this forum got such world reputation without your wisdom pearls and your humbleness so far, you're welcome.
door
Voeg je antwoord toe
richardkujawa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 2,361
