Gas Dryer heats and runs for 5 min and shuts off
Kenmore model 110.73942101 the dryer will heat up and run for about 5-10 min and then shut off. It will do this three times and then run great it will do it on every load. I have do all the test and every item checks out fine timer,thermister, heat relay and high limit switch I have also checked the resistance on the thermistor at the specified temps the gas valve coil test all meet resistance guidelines. I replaced the control board and it still does the same thing While doing all this I have noticed it starts to run and call for heat the igniter will have 1 volt at the plug but it will take about 1-2 seconds before it will start to glow and thats win it will shut off the dryer. What would cause this
Thank you
Vernon
Is dit een goede vraag?
1 Opmerking
Jim I did test all items many times but I replaced the parts thinking there may be a break down in the parts but it seems that the problem is an intermittent problem because it runs fine after the three shutdowns. I'm thinking that the PC board has a cold solder joint. Thank you for your help and wizdom.
door Vernon
