There are many possibilities.
Leds aren’t always accurate on electronics. But yes,that sounds extreme. It could be as simple as a bad battery. It could be a bad charger as well. I’d not those 2 things,it’s the circuitry. It could be a component issue.
If the battery life is fine,but just an inaccurate indication of battery,it could also be a faulty battery meter.
Sometimes charging until it won’t charge(keep it plugged in for a while after it hits 4th led or appears to stop charging),then drain it until it shuts off,then repeat the full charge step. In many devices,this calibrates the software meter for the battery,to make it more accurate.
have you tried using it for a while at a time? Is the battery life ok,setting aside the meter?
worse case,you could return it as defective,right? Just swap it out?
5 opmerkingen
now it wont fully charge. if its plugged in to the power outlet it says fully charged, same thing happened in my phones meeter(in the JBL connect). I then unplugged it and it indicates 80% power. its a defective device i guess. but i lost my receipt
door jed roman malata Deel
Same thing happened to me, the battery on the speaker is defective. You have to contact JBL and have them replace it or you can do it yourself if that's not an option.
door maxspeed3006 Deel
How do you change the battery yourself?
door Chelsey Toney Deel
My speaker is turning on but not charging.. I plug the charger in and it's not charging at all.
door sassyms.p Deel
I have changed my JBL battery and is not charging but the charging port is ok, what could be the problem
door Ambrose Deel
