Ga door naar hoofdinhoud
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Charging port not working
I have an ipad A1567 and can not find any info on it. The fire port needs replaced. How can I find it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Another option is to have the charge port replaced by a repair shop that does micro-soldering repairs. It should be less expensive than replacing the board.
Was dit antwoord nuttig?
Score 2
From a quick search I found that your device has its charging port soldered to the motherboard. Just look in the store for the logic board of your device instead.
yes but i do not see that ifixit sells this part :(
2 opmerkingen:
Yes but i do not see that ifixit sells it :(
door
This is the part you are probably looking for. iPad 4 Lightning Connector MAKE SURE IT IS RIGHT FOR YOUR MODEL. It should be an iPad 4th Gen Retina A1458, A1459, or A1460
door
Voeg je antwoord toe
Stephen Brackenrich zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 210
