Ga door naar hoofdinhoud
Sony DSC-H7 is a 8.1-megapixel Super HAD CCD camera which captures enough detail for photo-quality 16 x 22-inch prints.
7 Vragen Bekijk alle
Why does my camera turn on but won't extend the lense?
My camera turns on but the lense won't extend. The screen tells me “turn the power off and on again" but I've done several times and the lense still won't extend? What do I do?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Kim Sanch  there are a few things you can try to check on your stuck lens. Check on here. If none of that works you do need to take a closer look at the lens itself. Parts are difficult to come by for any repair of the lens assembly so you may consider replacing the complete lens assembly (part number is A-1268-104-A) .
Was dit antwoord nuttig?
Score 2
It could be the lens motor as well..
have ave you powered it off,AND removed the battery…then hold the power button for 30 seconds? If not,please try this and report back.
Voeg je antwoord toe
Kim Sanch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 193
