Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Half retina screen flickering when moving the mouse, blacks out
As the description says, my problem is that half the screen blacks out entirely and the other half flickers when you move the mouse. If you stop using the mouse, the entire screen blacks out. Everything seems to be working normal in the OS in the background. Any one seen this problem before? Might be the graphics card maybe? I has happened 3 times the last 24 hours.
I put a video here:
https://youtu.be/zUuBVegNvo8
Is dit een goede vraag?
1 Opmerking
To figure out what your exact model is, look at the bottom of your stand foot to find the serial number plug it in here: EveryMac - Lookup
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Your display assembly is damaged! I’ve seen this a few times.
I’m suspecting someone took off the display incorrectly and damaged the unit in the process. Sadly this will require a new unit:
  • [gekoppeld product ontbreekt of is uitgeschakeld: IF174-036]
  • [gekoppeld product ontbreekt of is uitgeschakeld: IF174-037]
You’ll also need this kit: [gekoppeld product ontbreekt of is uitgeschakeld: IF174-005] and you’ll likely need a few of these Plastic Cards
Here’s the IFIXIT guide to properly take the display off and to apply the adhesive strips on the new one iMac Intel 27" 5K Retina-scherm Vervanging van het scherm
Plastic Cards Afbeelding
Product
Plastic Cards
$2.99
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
I suspect you are correct about the root of the problem, BUT it has not been opened before. Could it be that a problem with the display "just happens"?
door
Basically the display controller board located on the top edge of the display got damaged. Take a look at Steps 5 & 6 in the iMac Intel 27" Retina 5K Display Teardown.
What I've seen is people use too long a tool which hits the ribbon cables damaging them. Here you might just have a bad display assembly. If thats the case (never opened) you should try getting it fixed under warranty.
door
Yeah , I thought so too @danj, but its older than 1 year, so I guess it will cost me. Might be cheaper to buy a new display.
door
I wouldn't throw the baby out with the bath water yet! Go to an Apple Store or authorized service center.
I think you still have a good chance getting it done under a 'warranty exception' but you need to press for it! Be polite but firm! You may need to work up the food chain, talk to the service manager and then the store and then the regional manager.
door
I do not have a Mac.
but yes it can be the graphics card. It could be an os corruption. When you power it on,is the screen black?
Score -1
1 Opmerking:
To determine if I a Mac has a actual display problem or the GPU is defective, I hit cmd-shift-3 to make a screenshot while the flickering etc. is happening. If You see the errors on the screenshots, the GPU actually rendered the picture wrong and it's a high chance it's defective. If the screenshot is clear it looks like the GPU renders correctly, but the screen doesn't display it correctly.
door
Voeg je antwoord toe
peterhso zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,386
