Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
Samsung Galaxy S5 display replacement
Hi,
I have removed the broken display from my phone, unfortunately the copper labels are damaged. Could this be a problem with a new display. Should I replace them and if yes where can i buy them?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Smint,
The copper labels should not make a huge difference if you do not replace them. That being said if you do want to just in case you would probably want to buy a whole mid frame assembly with them attached. Galaxy S5 (Verizon) Midframe
Good luck!
Galaxy S5 (Verizon) Midframe Afbeelding
Product
$13.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you very much for your answer!
door
Voeg je antwoord toe
Smint Gs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 36
