Ga door naar hoofdinhoud
Released in 2012, this is a durable PC laptop for the everyday computer user. This model (NP540U3C-A01UB) features a 13" screen, a 500 GB hard drive, 4 GB RAM, a DVD multi-drive and is capable of running Windows 8.1.
24 Vragen Bekijk alle
Help, can't install an OS
So here’s what happened, I tried to install Ubuntu onto my laptop and when I restarted it, well it didn’t detect any OS anymore despite me leaving the USB inside. (It was originally a windows 10)
Now whatever I do, it doesn’t detect any USB input, let it be a USB keyboard, mouse or drive. The only thing I have access to is my BIOS.
It doesn’t seem like my laptop still has an OS and it refuses to do anything else.
Letting it boot normally gives me:
“All boot options are tried. Press F4 key to recover with factory image using Recovery…“
After pressing F4, well it doesn’t detect anything and goes on it’s merry way back to the afore mentioned quote.
Thanks is advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @kansysaea ,
In BIOS change the Fast BIOS mode setting to disabled
When Fast Bios mode is enabled it skips USB check during POST.
Go to BIOS > Advanced > Fast BIOS mode
When exiting BIOS (F10) save the changes (Y).
When the laptop restarts you should be able to boot from a USB device.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
thank you very much @jayeff for your wonderful advice. It works
door
Thanks jayeff ! , works too in UEFI mode
door
Voeg je antwoord toe
Andrew Kansy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,692
