Hi, this helps to me…
Works for macOS Sierra and High Sierra (Improved version)
Taken from StackExchange
Thanks to LangLangC
For temperature and other improvements see https://gist.github.com/cdleon/d16e7743e...
Shutdown, unplug everything except power and hold
leftShift + Ctrl + Option + Power
I holded for 5 seconds, but holding just for an instant should work
Command + Option + p + r
Until you hear the startup chime two times.
if you are on high sierra 10.13.6+ you might need to use Command + r instead
Command + r + s
csrutil disable
nvram fa4ce28d-b62f-4c99-9cc3-6815686e30f9:gpu-power-prefs=%01%00%00%00
nvram boot-args="-v"
reboot
Command + s
It might look as if it hanged, but press enter and you should see the shell (root#)
/sbin/mount -uw /
mkdir -p /System/Library/Extensions-off
mv /System/Library/Extensions/AMDRadeonX3000.kext /System/Library/Extensions-off/
touch /System/Library/Extensions/
reboot
It will show a bunch of text in the screen (don't be alarmed, let it finish) and then it will restart again In second restart it will show text in the screen again and then it will show normal login screen Your computer now should work properly (dGPU off and iGPU on, shown as i in gfxCardStatus
BIG CAVEAT FOR APPLE UPDATES
If an update that contains changes to the AMD drivers is about to take place it is advisable to move back the AMDRadeonX3000.kext to its default location before the update process. Otherwise the updater writes at least another kext of a different version to its default location or at worst you end up with an undefined state of partially non-matching drivers.
After any system update the folder /System/Library/Extensions has to be checked for the offending kext. Its presence there will lead to e.g. a boot hang on Yosemite and Sierra, an overheating boot-loop in High Sierra.
2 opmerkingen
What happens when you go into Target Disk Mode? Does the screen look OK then? Restart the system and hold the T key.
Reference: Mac startup key combinations
door Dan
I’ve just tried target disk mode it works fine. The screen worked and the drive mounted on the connected computer
door David Jennings
