Home and Turn button
Hi, my iPhone 3G was fall and I fix my LCD and Touchscreen. It turn on, seed everything is OK but home button won't work and also won't work turn off button. Please help.
Is dit een goede vraag?
open the phone again and check the 2 gold prongs at the back of the home button..they often get flattened when you repair the display. use a flathead screwdriver to gently lift them up to 45degrees. as for the power button try to reseat the flex connection no 5 and see if that helps.
Was dit antwoord nuttig?
Big Thank about Home Button now it works correct, but I have still problems with my Sleep button and I observe when I click to camera i won't work (not open grey jalousie) :-(
you'll need to check that it is on properly, it may have shaken loose of it's connector when you dropped the phone. it means taking out the motherboard as the connector is on the back. then you can check out your power button/flex too. if you dropped the phone hard enough to damage a screen and camera, the power flex may have a tear. take a look at the guide (link is under the photo of the phone to the right)
Thank you very much. I replace all orange ribbon cable with connectors and replace the camera. Now it works correct. Thanks you. But when I insert my Sim card phone didn't find any provider and on the screen write NO Service :-( unfortunately I broke a little bit connector Nr.4 but it lock to board. May it be the problem about Low receive antenna ?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 622
1 Opmerking
door WSharky
