Ga door naar hoofdinhoud
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239 Vragen Bekijk alle
How do I make the second monitor active if primary is down
Normally I would use Command F1 to make the external monitor active but there is no F1 key on the touch bar. Also the screen is broken so i can’t get into system preferences on the primary display. Need to turn off autoboot before putting new display on.
@danj
Is dit een goede vraag?
Score 3
8 opmerkingen
Won't removing the battery prevent the Mac from turning on whilst repairing it?
door
see step #1 Step 1 Disable Auto Boot on this guide. Just trying to follow directions
MacBook Pro 13" Touch Bar eind 2016 Vervanging van de schermmodule
door
I got the bottom off without activating the power on. Not easy!
door
@mayer I'm at a loss of understanding that removing the lower case could trigger the fastboot?
door
Obviously somebody did it or it wouldn't be in the guide. Lots of things get put in guides because someone had to first do it wrong.
door
3 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I just spoke with an Apple employee over the phone and she said that if you disconnect the battery before doing anything else you should be fine and fastboot shouldn’t be triggered. Someone is going to lose their job… LOL
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
If you did that much of a favor for me, I'd say NOTHING to protect your job. Don't give their name out.
If you want to get anywhere, sometimes you need to protect people who give you the info you shouldn't get.
door
@nick I was in utter shock that this particular employee gave me this information, I'd have to say. Before hanging up with that employee I told her that "iFixit thanks you" and "you are the type of person working for Apple that is actually helpful when it comes to technical support".
door
She's probably tired of Apple's crap. That's probably why you got that info.
door
Personally I am too. It's just a matter of time before the T2 chip completely locks down Macs from being user-servicable. I am dreading that fateful day that someone comes across this forum asking why their Mac won't boot after a modification to an internal part.
door
Voeg je antwoord toe
mayer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 311
