Ga door naar hoofdinhoud
Where to get high-temperature foam?
I replaced the battery on a Macbook Air, and the battery connector keeps coming loose. I think that the best solution would be to tape a piece of foam on top of the connector, so that when the Macbook is reassembled the connector is pressed into place by the bottom cover. I am worried about the temperature, so I am reluctant to put on just any piece of foam. Does anyone know where to get high-temperature foam, especially pieces that have adhesive backing?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Just use a piece of Kapton (Polyimide tape ) tape on it
Polyimide Tape
Kapton is a polyimide film developed by DuPont in the late 1960s that remains stable across a wide range of temperatures, from −269 to +400 °C. Kapton is used in, among other things, flexible printed circuits and thermal blankets used on spacecraft, satellites, and various space instruments.
Polyimide Tape Afbeelding
Product
Polyimide Tape
$9.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you for the suggestion. I have ordered that and plan to use it. Maybe that is all that I really need. However, I was hoping to get, in addition to that, some foam to provide additional hold-down or press-down force. I know it must exist, because there are pieces of foam inside of the Macbook, on SSD drives, etc. If you or anyone else can suggest a high-temperature foam product I would be grateful.
door
Voeg je antwoord toe
Tom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 83
