Ga door naar hoofdinhoud
How to apply thermal paste?
I have read the guide on thermal paste; however, I just want to make sure I do it correct. My powerbook g4 12" has thermal paste on one chip and thermal pads on two other chips. Can the thermal paste be applied to all the chips? Or should I put thermal pads on the two that have it on them?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I don't use the pads at all. I just use a thin layer of paste. You're just trying to transfer heat.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
What is the normal temperature range for the CPU on the powerbook G4?
door
You might want to download and install "Temperature Monitor", I think they have an archive of normal temperature ranges: http://www.bresink.com/osx/TemperatureMo...
door
Voeg je antwoord toe
kathleeng6 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 1,525
