Ga door naar hoofdinhoud
My MBP does not go off, BUT RESTART
MacBook Pro 17" Models A1212
Immediately restarts every time I try to shut it down or put on stand-by, if I close the screen continues to reboot without stopping. The only way to shut it down is to hold down the power button.
If I try to shut down the terminal, the result does not change, it will restart immediately.
Groped to solve the problem, I tried everything I knew, the brief summary:
- I have repaired the hard drive with the appropriate utilities, and the program has reported that it had repaired some areas. - I have repaired permissions
- I formatted (Snow Leopard) by initializing the disk.
- I did all the upgrades I noted that the system automatically
- I reset the PRAM (x 3 times) and the SMC.
- I replaced the RAM
I did the hardware test and it gave me this result:
4M0T/1/40000002: Left side
At this point I do not know what to do, I can take it apart, but I have not the faintest idea what kind of hardware could cause such a thing.
Note that for the rest of the machine works perfectly.
Thank you in advance for your attention.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I suspect that one of your fans has failed. Download and run smc fan control and see what it tells you: http://download.cnet.com/smcFanControl/3...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
ok, I'll try as soon as possible, but that relationship may exist between warming and the fact that it will not shut? I have confirmed that the error code from the hardware test, refers to the fan left who does not work, but how this may affect the shutdown?
door
Voeg je antwoord toe
davidegatt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,109
