MacBook kernel panic reboots
Wondering if there’s a quick fix or a workaround
Is dit een goede vraag?
Found my workaround this fixed my issue to all who reads this this helped me out it disables the bad graphic card
Was dit antwoord nuttig?
What happens when you boot up in Target Disk Mode? Restart your system and hold the T key, do you get the Thunderbolt Icon on your internal display?
If yes, try booting up in Safe Mode holding the Shift key what happens then?
Lastly, lets run diagnostics holding the D key when you restart. Did you get an error?
What I’m trying to do here is to locate what is failing as the crash report error is not very clear. If you can post the original text file instead of the JPEG snapshots so its more readable.
Reference: Mac startup key combinations
Ok thank you for the response well I added the text file up in the original post
panic(cpu 0 caller 0xffffff7faccc5705): "GPU Panic: mux-regs 3 0 a0 d9 9 8 severity 3 - - - - AppleMuxControl/kext/GPUPanic.cpp:149
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 2,040
2 opmerkingen
Which model do you have?
- MacBook Pro 15" (Intergraded Graphics)
- MacBook Pro 15" (Dedicated Graphics)
door Dan
Hi dan I have a early 2013 MacBook rentina dual graphics
door tyguy764
