Ga door naar hoofdinhoud
The Samsung Chromebook 3, introduced in 2016, is the successor to the Chromebook 2 and features an Intel Celeron N3060 processor. The XE500C13-K01US model has 2 GB RAM while the XE500C13-K02US model has 4 GB RAM.
17 Vragen Bekijk alle
Chrome book not powering on
I powered off my chromeboom due to a Wi-Fi problem and it just wouldn't power back on still shows a charging light and has a full charge.
Other things say to use refresh button and power button to soft reset the device but that doesn't work.
Is my best bet to open the bottom panel and disconnect the battery?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Try pressing Esc + Shift + Refresh + Power all at the same time. If that works, it will force restart your chromebook and hopefully it will power on. Just my two cents.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Tried this, I get a white light led indicator that flashes when I push the power button and refresh button
door
Voeg je antwoord toe
Trevor Weaver zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 417
