Milk Frother not producing steam or water
When I press steam or water button, steam or water squirts once but the rest of the water gets collected in the tray below. Coffee maker side is working without a problem.
I have even removed the frother assembly from silver pipe but same result.
Please suggest what is the problem.
Is dit een goede vraag?
3 opmerkingen
same exact problem with a C9. I have previously rebuilt the brew group and replaced all the o-rings in the unit. coffee brewing works perfectly.
when you hit the milk froth button with a milk dispenser connected and frothing knob at 12 O clock position, it shoots some steam and water in the cup for a a couple of seconds and then stops. you can still hear the pump going and see steam coming out of the center of the machine. Opening the machine up shows that while frothing hot water is flowing to the brew group instead of the frother output. I have already tried replacing the steam (thermoblock output) valve - it had no effect at all
I have already tried replacing the steam valve.
door Brad
took some digging, but for my problem this german jura forum (komtra.de, link in next comment) describes the exact same issue. there is a steam solenoid valve and a thermoblock outlet valve. when you describe the problem to folks they point to the outlet valve as the likely problem. makes sense, since steam is coming out of the brew group area instead of the frother right?
Well I replaced that outlet valve and no joy.
door Brad
You have to remember the steam is under pressure. what if a valve that is supposed to open to let steam out does not open (or does not stay open long enough)? pressure will build up after a few seconds, forcing the outlet valve open. You WANT THIS to happen if the steam valve is stuck closed or closes early! it will keep the machine safe and also prevent leaks from the machine.
So bottom line I have ordered a Jura steam solenoid valve. Will post back and let you all know how it goes.
here's the german website, in english through google translate
https://translate.google.com/translate?s...
door Brad
