Ga door naar hoofdinhoud
Why is my phone not switching on?
its actually nokia 6.1 plus not nokia 6… its a new phone . I was using it on low battery and then suddenly found a bug on the screen . So I restarted it but it is not switching on now!
someone pleeeeeeaassee help
Is dit een goede vraag?
1 Opmerking
My Nokia 6.1plus battery does not charge.
Is there a problem with the charging board?
Is this the charging board Nokia 6.1 plus his original ?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello,
Try pressing the power+volume buttons to hard reset the device in case it doesn’t work please take the phone to the nearest service center to get a closer look at the issue.
Hope this helps….
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Greatly appreciated your advice! It worked. Thought I was sunk ... and looking around for a pro until I read your advice.
door
Voeg je antwoord toe
Eeshdeep Singh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,125
