Ga door naar hoofdinhoud
iPhone 7 touch id will work after removed u10 chip?
my iPhone 7 home button not working , one of third party technician was tried to replace u10 chip but unfortunately while removing damaged my upper flex ( attached steel round button) and also he was failed to re install u10 , now my iPhone home button not having chip and also touch id not working
just i wanted to know the confirmation that if replace the u10 my touch id will work again or not ?
please let me know
EDIT:
Update (10/26/2018)
this marked upper flex damaged
it can be repair with jumpers please let me know
i want atleast Touch ID instead of home button
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I suspect that the flex was damaged, which is why the Touch ID is not working. If this is the case, then a U10 IC will not make a difference. Normally, a damaged U10 does not impede the function of TouchID.
Can you post some pictures so we can see the damage?
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Post a picture of your actual HB please.
door
Voeg je antwoord toe
feroz_khan77874 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,210
