Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
103 Vragen Bekijk alle
Why is my screen has a high contrast even when turning it down?
I just saved this old mac from being thrown into the garbage by my college surplus store and fixed it up. However, every time I boot it up, it has a whitish screen and then I have to put it to sleep for a few minutes and it will look fine. Is there an issue with the lcd or video card?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sadly your logic board has a problem. I suspect one or more of the caps or solder joints in the GPU logic has degraded so it needs a bit of time to warm up to work.
Your logic board has the GPU chip mounted onto the main logic board it doesn’t have the MXM GPU daughter board design.
I would leave things alone and live with it. If you really want to fix this it will take someone with good board level diagnostic skills.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Bau Pham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 39
