Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Vragen Bekijk alle
The Installer payload failed signature check.
I’m trying to install Sierra on my mac and i’m having trouble with getting past the error “The Installer payload failed signature check.” I’ve reset the time, installed new ram, and wiped the drive. Any suggestions?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try downloading another copy of Sierra and creating a bootable USB with that installer. Your current copy is either fraudulent or corrupted.
Was dit antwoord nuttig?
Score 1
15 opmerkingen:
I work at a Phone/Computer repair store and we have "known good" usb drives. were going to try and install El Capitan And see where that leads us.
door
@danj Yes, we have inputted the correct date and time settings.
door
@acervasio Just making sure you are doing the bootable USB process correctly; You are downloading the ElCap/Sierra installer from the Mac App Store and you are then creating a bootable USB using "createinstallmedia"in Terminal. Correct?
door
Where did you get the installer? I strongly recommend you only get it from the Apps Store. Other sites that offer the file could have altered it.
door
10 commentaren meer tonen
Voeg je antwoord toe
Austin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 39
Altijd: 6,415
