Ga door naar hoofdinhoud
De TI-84 Plus CE is een grafische rekenmachine die in het voorjaar van 2015 door Texas Instruments werd uitgebracht. Hij beschikt over een 2,8-inch kleurenscherm, een USB-poort, apps, opslag en een 1200 mAh-batterij.
How can I fix my flashing screen (TI-84+CE)
My calculator seems to have decided to no longer likes me, and is having startup issues.
It is stuck on a flickering white screen. I can’t turn it off. It doesn’t seem to be turning off on its own. I’d prefer to not have to completely wait for it to drain considering that I just finished charging it yesterday. The calculator does not seem to fully load at all and does not appear in the TI Connect CE program when plugged in to the computer. This is my personal calculator and I’d really like to have it fully working again, and if possible, salvage the programs I have on it. Is there anything I can do, short of buying a new calculator? Or is there a factory reset feature available anywhere I can use?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try doing the recovery techniques listed on the guide I have linked to below. Hopefully one of those techniques will work for you.
TI-84 Plus CE-hersteltechnieken.
Was dit antwoord nuttig?
Score 10
4 opmerkingen:
@thelastmill This problem was solved compliments to your wonderful guide, thank you!
door
Performed a hard reset on the calculator by clearing the ram using the button on the back and just redownloaded my programs. The slideshow above is also extremely helpful. Thanks!
door
@ahvey Glad it was helpful! Happy fixing!
door
I'm glad it was useful! :D
door
Voeg je antwoord toe
Matt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 90
Afgelopen 30 dagen: 446
Altijd: 56,446
