Ga door naar hoofdinhoud
The third generation Pixel released by Google in October 2018.
20 Vragen Bekijk alle
Rear glass panel cracked repair?
I dropped my phone and cracked the rear glass panel and the glass on the rear camera lens? Everything still works perfect but is it possible to change the back glass panel?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This phone is quite new. I would check with Google to see if they will replace the glass for you under warranty. At the time of this post there is no such camera lens or back glass existing for your phone yet so in my opinion it would just be worth it to pull out your wallet and let Google handle this.
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
Thanks for the advice. After speaking with Google customer service they are going to replace the device for me.
door
Kenneth how much did they charge you for a replacement as my device has a corner crack in same area and again works fine other than random white flashes it does when it locks and unlocks it's kinda due to the flashes how I dropped it as it gave me a freight
door
I had this repair done at UBreakIFix for $107 total, parts and labor.
door
@coltdorsey , how was the quality of the replacement?
door
Ubreakifix is a Google partner so they get OEM parts straight from Google.
door
Voeg je antwoord toe
Kenneth Way zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 11,315
