Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
20 Vragen Bekijk alle
Why is my asus x555qg laptop running so slow
my laptop is running so slow it just started running slow for no reason about a day after its warranty ended its got an amd a12 3.4 ghz CPU and 8gigs of ddr4 soldered ram and a amd radon r7 and r8 2 gigs of gpu ram oh and don't forget the 5200 rpm hdd
Is dit een goede vraag?
1 Opmerking:
Hi @saltyboat ,
Have you done an Anti Virus scan or an Anti malware scan to see if this is the reason for the performance issue?
Check Task manager > Startup to see what programs are being loaded at startup that may be unnecessary and are slowing the laptop.
Have you checked Event Viewer to see if there are any events listed that may impact on performance?
What have you checked?
door
Voeg een opmerking toe
1 Antwoord
Hi jack
look for any windows updates than try to uninstall any program that you don’t needed and restart your pc and see if any change
Good luck
Was dit antwoord nuttig?
1 Opmerking:
I have already tried that and I’ve reset it about 5 times making no difference.
door
Voeg je antwoord toe
jack zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 428
