Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Vragen Bekijk alle
Trackpad click not working consistently
About a month ago the trackpad stopped being consistently responsive to clicks. It still does respond to clicks along the right side of the pad, but on the middle and left sides it almost doesn’t work at all unless you apply some considerable force — not a ton, but more than is customary. The touchpad works normally otherwise — moving cursor around and tapping works across the entire face of the pad.
Wondering if this is a situation that requires replacing the touchpad or if I may have a loose connector or something.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Check to see if the battery is swollen and putting pressure on the bottom of the trackpad.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Well it is several months later (because it took me a long time to save up for a replacement battery) but this was the cause. The battery had indeed swollen a bit. In fact, the battery had been in poor shape for a long time before this, holding roughly 10-15 minutes of charge at a time and macOS had long since been telling me to replace it.
I ordered the kit from ifixit and took care of it last night. The touchpad works like new, now. Thanks, @mayer, for suggesting this as it hadn't occurred to me at all.
door
It is always worth the try to see if the cable is loose but if you determine it is fully and properly connected it is probably time to replace the trackpad.
MacBook Pro 15" Retina (Mid 2012-Early 2013) Trackpad
Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015
MacBook Pro 15" Retina (Mid 2012-Early 2013) Trackpad Afbeelding
Product
$39.99
Score 1
Voeg je antwoord toe
James Candless zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 787
