Ga door naar hoofdinhoud
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
147 Vragen Bekijk alle
Showing as charging when not please read comments
In October 2017 I purchased this and a keyboard as a bundle for Xmas. In February it started with the above problem I was given a new replacement, in October it happened again yesterday I got it back another new one and it’s doing it again my question is can I request a full refund and would I approach the shop or apple many thanks
Is dit een goede vraag?
3 opmerkingen
is the keyboard an Apple keyboard, are you still using the original keyboard? I have had faults occur from the keyboard. Try charging etc without the keyboard and see if that makes a difference.
door
It is the original charger. There is nothing connected when it makes the charging chime and shows the picture of the battery it is charged
door
Yes Apple keyboard bought as a bundle
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Are you using a Bluetooth keyboard or a wired one? Can you provide a link to the keyboard in question?
I ask because wired accessories can cause issues with the charging circuit of iDevices. An MFi-certified accessory should be fine but even then, you never really know until its too late ;>).
When troubleshooting charging issues, I would do the following (in order):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units. Make sure you are using the proper charging brick, in this case the 12W charger.
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with fine point toothpick. Just be careful not to damage the pins inside the Lightning Port.
  3. Change the battery. The battery is the weakest link in the entire device and certainly for charger related issues. However, replacing the battery is not a trivial undertaking. Instead, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  4. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging.
  5. If a new battery and charge port still don't resolve the issue, then you may have a logic board issue. There is an IC (commonly referred to as Tristar) responsible for communicating with the charging device and uncertified chargers can damage it.
Was dit antwoord nuttig?
Score 3
You might need a more powerful USB power adapter. What is wattage power on your USB power adapter?
To find your wattage rating on the white USB charger, one of the sides will have ink in light tan or grey. If you look at the top line, there should be some words that say: “10W USB Power Adapter” or something along those lines.
If you’re using your iPad with a 10 Watt USB Power adapter, you’re going to be using power faster than the battery can charge even when you’re plugged in. This a common issue. You have 2 choices: 1) Let the iPad battery charge for a few hours with no use. 2) Upgrade the power adapter. To do that, you need to purchase a 30W USB Power adapter (~$50) and a Apple Lightning to USB-C cable (~$20 for 1 meter, ~$30 for 2 meters). You can find them at Target, Best Buy, and Apple’s website.
3 opmerkingen:
The 30W charger is not slated for compatibility with the iPad Pro 9.7" but I agree that you shouldn't be charging a large iPad with the 5W brick, instead use the 12W brick (link in my answer).
I don't doubt it works though :>).
door
It is blue tooth I think. It magnetically clips on the side I think it may be the keyboard as I have now had three new ones in a year and using the same keyboard it's under warranty can I get a full refund
door
Lianne if you still have your receipt and it has been less than a year, yes you should be able to to exchange or return it. Keep us updated!
door
Voeg je antwoord toe
Lianne inglis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 108
