Ga door naar hoofdinhoud
Reparatiehandleiding voor alle toetsenborden behalve die van Apple.
242 Vragen Bekijk alle
Will these wired keyboards destroy the tristar on an iPad 6th gen?
I have seen some teachers giving out non-genuine knockoff wired keyboards to be used with school district issued iPads. I also know that using non-genuine lightning accessories can destroy the tristar chip on Apple devices with a lightning port so this kinda worries me to the point where I want to spread awareness of this danger of tristar failure.
Should I have a reason to worry? I use a Bluetooth keyboard with my district issued iPad instead of a knockoff wired keyboard just to avoid this issue.
@refectio @jessabethany Ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s always possible with non certified accessories. The problem is that they require power from the device and if they don’t have built-in protection circuitry, they can expose the iPad to high power requests and damage the logic board. Like anything else, it’s a numbers game and the probability that any one keyboard damages a Tristar IC is low but when you scale it up, you see problems.
IMHO, from a school district perspective, they should not be allowing non MFi-certified accessories being connected to school owned iPads. With the high number of devices, they will see problems…eventually.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
@refectio Thank you! I will be sending an email to my school’s District Technology Specialist about this matter. Hopefully they will wake up and spend the extra dime for a Bluetooth enabled keyboard after realizing the dangers of non-MFi certified accessories.
door
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 79
