Ga door naar hoofdinhoud
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
How to fix this
This connector has deteriorated and any idea on how to fix as this is the home button ribbon connector
Update (10/16/2018)
ok here is the broken connector whats missing is the friction bar
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You’ll need to have the connector replaced however that will require a micro-soldering repair and is not a DIY type of repair.
As for repair, look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. There are many shops worldwide that do this so you shouldn't have any problems finding them.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
has anyone got a good idea for a quick fix as I am going to upgrade it soon, just waiting for x-mas sales.
door
Well, if you show us a picture of the actual connector, we may have some ideas. But if the connector is damaged, it will have to be replaced.
door
If you can find the friction bar, you may be able to re-insert it. Otherwise, you'll have to replace the connector.
door
Voeg je antwoord toe
Service By George zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 104
