Ga door naar hoofdinhoud
Reparatiehandleidingen voor een groot aantel Panasonic digitale camera's.
348 Vragen Bekijk alle
Why will my FZ18 not turn on, batteries are all good
My FZ18 wont turn on and batteries ( I have 4) are all good. Initially when I put a freshly charged battery in I could take a photo and then the camera would shut down and not start up again so don’t know if it’s immediately discharging battery but now just dead
Is dit een goede vraag?
2 opmerkingen
Hi @higgi ,
Try exerting a bit of pressure on the battery/card door i.e down and in, whilst trying to turn on the camera.
I don't know if it is applicable for your camera but some have a microswitch on the battery door which operates to ensure that the door is fully closed. It may be loose etc.
Just a thought.
door
Thanks jayeff for the try but nope it still won't work
Cheers
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Is there any error message displayed on the camera LCD? When you take a photo, does it say "please turn the camera on and then off again" Or does it immediately shut off? Try inserting the battery into the camera and hold it in while turning it on. See if it stays on. Maybe the battery housing got slightly damaged from a fall and the battery is not seating in properly.
Good luck!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi Anthony, thanks for the answer but its just totally dead, will not turn on at all. The cameras never been dropped and unless using always been kept in its case. Tried your remedy but nothing.
Cheers
door
Have you tried with an external power supply? 8.4V power supplies are widely available and cheap. You will probably need an adapter to fit the socket on the camera.
Search on ebay (for example) for something like “8.4V 1A Mains AC-DC regulated Power supply”
and then for “8 in 1 AC DC Power charger adapter tips”.
But maybe check the switch first: the switch on the case can come disengaged from the “real” switch on the circuit board. That would explain the problem. But that involves opening the case. The service manual is available online, but doesn’t exactly match my FZ18. I would post a link to a blog where I describe how to open the case, but ifixit seems to dislike such links.
1 Opmerking:
Hi Querty, thanks very much for your answer but have since sold the camera for spares. I couldn't even get a specialist to look at it as they said parts were obsolete. So still need to get another camera
door
Voeg je antwoord toe
Dave Higgins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 235
