Ga door naar hoofdinhoud
This 2012 navigation system includes maps of 49 states, the Bahamas, the Cayman Islands, Puerto Rico, and the U.S. Virgin Islands. Users can recognize this device by checking for "Nuvi 50LM" on the bottom of the GPS.
12 Vragen Bekijk alle
I cannot change the home location on my device
I purchased unit 2nd hand, however I am unable to set it to my home state and location, keeps referring back to original Location ( Texas) in currently in AZ I cleared all the ‘Favorites” but still wont load up maps or allow me to set it for AZ, actually AZ doesn’t come up in the state search
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
When searching for an address, your device will automatically search for matching addresses within the state or province where you're currently located. When near a state line, the device will also search in the neighboring state(s).
To search for an address in a different state:
  1. Touch Where To?
  2. Touch Address
  3. Enter the house number
  4. Touch Done
  5. Enter the street name
  6. Touch Next
  7. Touch the Searching in button
  8. Enter the desired state
    • You may also enter a city or a city/state combination
  9. Touch Done
  10. Confirm the desired state
The device will now search for matching addresses within the specified city and/or state.
To search for an address within a specific city, you may also follow these steps:
  1. Touch Where To?
  2. Touch the Searching near button
  3. Touch A Different City
  4. Spell the name of the city only
  5. Touch the green magnifying glass or the desired city name in the blue search results
  6. Confirm the desired city and state
Now that the city and state are set, you may continue the address search as described in steps 2-6 of the first set of instructions above.
Alternatively, you may use the quick search bar at the top of the Where To? menu to enter the entire address all at once.
Please refer to the devices '''owner's manual''' for instructions on enter coordinates.
If the steps/instructions above do not work for your device, click on Support Center and enter the Product Name or the Serial Number of your device.  Once your device is entered, search the FAQs under the Common Topics or select Other to search using your own search terms.
Hope this info is helpful.
Was dit antwoord nuttig?
Voeg je antwoord toe
jeff mccarty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 2,170
