Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor alle huishoudventilatoren.
207 Vragen Bekijk alle
Fan keeps falling over
Hi can someone help I don't keep to good so I have a tall cooling fan at my bed its on 24/7 over the last month it keeps falling over and the tilt keeps dropping down it as if the fan bit is to heavy for the stand. Thank you Susan
Is dit een goede vraag?
1 Opmerking
Hi,
What is make and model number of the fan?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
In addition to what Dave said, if the pole is wobbly on the stand, there is usually a threaded nut on the bottom of the stand where the pole goes through it. This nut may have loosened up due to vibrations from the fan. Tighten it up.
Was dit antwoord nuttig?
Score 3
Is there a knob on the side of where the fan connects to the stand? If there is try putting it in the position you want and tighten it until the fan stays put. Or, you could fabricate a secondary stand for it to hold it up where you like it to point.
Score 1
Voeg je antwoord toe
susangillan35 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 138
Altijd: 3,512
