Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
You may not install this volume because the computer is missing a firm
Mojave installs just fine on an external drive, the when put into the machine it destroys the drive to the point of being unable to even format it or even see it.
When trying to install internally I get the popup,
“You may not install this volume because the computer is missing a firmware partition.”
If I install a partition with Disk Utilities I get the same thing.
If I run into someone who helped write High Sierra or Mojave and included these obstacles to make older Macs obsolete, is it Justifiable Homicide if I strangle them with my bare hands? Or should,I just carve an Apple logo into their foreheads?
I have five machines MBP 2011-12 on my bench right now that were upgraded with Seagate SSHD drives. All are now non-functioning because of High Sierra updates and I can’t fix them. I’ve already replaced about a dozen drives out of my pocket because of this. I sent emails out to all my customers with SSHD drives not to upgrade a couple of months ago.
UPDATE
OK I tried just a standard Apple 500 GB drive. Formatted it externally. Put the drive in the MBP 13” 2012 non-retina machine and get the same “You may not install this volume because the computer is missing a firmware partition.” So Pulled it wiped it again and put it in the machine. Did an internet recovery and install the original Mavericks. Dropped on downloads od El Capitan, Sierra, High Sierra, and Mojave. Will install them all in order until I get a failure and report back. @ajcooke01 @danj
Still think Tim Cook would look good to me with that Apple carved into him.
UPDATE
El Capitan installed, no problems but noted no firmware updates. Going for Sierra now.
Sierra OK, doing the updates now.
UPDATE 10/5/18
Took the standard Apple branded Seagate MX 500GB all the way to Mojave and it’s running OK.
Now I tried a clean install of Mojave on a Seagate 500 GB SSHD older model. and all went slick. Did Migration. Now when I try to start, it takes forever for the loading progress bar to complete, especially the last quarter of an inch and NO JOY. Cannot get it to fully boot. Will be trying various cures today. This is really depressing as I have installed a couple of hundred Seagate SSHDs both the FireCudas and the older models. When trying to boot in Safe Mode, I get the Apple logo flash on, then a circle with a line through it, then it starts to load, get 1/3 of the way and the machine shuts down.
UPDATE 10/6/18
I put the stand drive back in internally and it booted just fine.
Hooked up the SSHD externally and repair attempts failed. It did show up titled as APFS Media. So the software install has put that APSF on again. After four attempts I was able to reformat it OS X Mac Extended. @danj, not sure what to try now except to take it down to Sierra. Any suggestions?
Is dit een goede vraag?
Score 5
3 opmerkingen
@mayer settle down there good sir, just replace their toothpaste with thermal paste. ;-)
Have you tried the APFS formatting scheme? Have you tried installing the Mojave installer app onto an internal SSD/HDD with High Sierra on it and then installing it via the installer app?
Also, are you sure that this HDD/SSD works 100%?
door
Simply download Carbon Copy Cloner. First 30 days its free. Use CCC to create a firmware partition on the target OS disk. Then install Mojave!!! Easy. See how it pays to know the right people. Regards, Barron Hall. Chief Wealth Creation Mentor for DollarBillioniare.com.
door
When the firmware partition is messed with (ifi) its an attack to make it appear as if your components ( mother board, video card, wifi, bt are breaking down, obsolete etc, dont fall for it, test the parts your self, its all software and a scam to extort users i to buying a new mac/device or simply to bringing their computers to apple scam store and trust them with their data….you can re install the firmware by restarting in recovery mode.., then clone back or upgrade all the way to Catalina but dont go as far as the last version, the security updates are basically programs to remove support for 3rd party devices, accessories and other functions of your device and or computer,nothing else,
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
@mayer - Hold on here! You’ve thrown the baby out with the bath water!
Lets back up….
Apple applies EFI updates with EACH OS release! So the root issue here is the system does not have the REQUIRED firmware to work.
We hit this already with HFS+ to APFS with High Sierra. Where people would have updated their system and then they needed to replace the logic board and BAM! dead system as the drive was updated but the new logic board still had the older firmware.
So the only way to upgrade the logic board is to install a spare drive or use an external, then you have to go through the OS install process.
So you’ll need to do the same with a standard drive. Then lets see what happens then.
Was dit antwoord nuttig?
Score 2
12 opmerkingen:
APFS clearly causes more problems then it's worth.
It should be OPT IN; not forced.
door
Only an issue with SSD's! And you can program the installer not to upgrade How to: Upgrade to High Sierra without changing the file system to APFS
Take a read of these:
- The Speed of APFS Just How Fast Is It?
- Using APFS On HDD's... And Why You Might Not Want To
Now to be fair this are based on the first release of APFS and Apple has altered things in Mojave so we will need to see what falls out. Even still on PCIe/NVMe drives it makes a lot of sense! Just not on HDD's SSHD or SATA based SSD's
door
@danj as I stated, I am now trying this with an Apple branded straight 500GB hard drive no SSHD. I got the error when trying to install on a clean drive. Am now going through all the system upgrades, it just takes a while. But I think Apples intent was malevolent. I mean we are professionals and can't get it to work. The average Joe is SOL!
door
@mayer Agreed. Apple has just become so greedy since Tim Crook inherited CEO, all they want is you to buy new stinkin computers that are not repairable at all and they are just about hotter then the sun too. It’s unreal, and that’s why I stick to my old Macs (I still use a 2008 Core 2 Duo MacBook to this day!). iFixit saved my butt multiple times when my older Macs have broke down, so a big round of applause for iFixit.
door
@ajcooke01 iFixit helped you or was it the people who provide the answers, for no thanks?
door
7 commentaren meer tonen
Het nuttigste antwoord
Dear all,
I had the same problem. Macbook Air 2013, internal SSD failed, and too expensive to be replaced. So I bought a 256GB Sandisk USB to install MacOS.
Initially, I Command-R to boot into recovery and tried to reinstall MacOS, but original was Mountain Lion. Installation was successful, but I wasn’t able to further upgrade to Mojave due to “.. missing firmware” issues.
Here is how I resolved:
  1. created Mojave bootable installation USB drive
  2. Boot into system with the above USB drive
  3. Before attempting installation, make sure to use Disk Utility to Erase/Partition the drive (USB thumb drive in my case) to APFS - IMPORTANT
  4. Exit Disk Utility, then click on MacOS install, which would proceed with the installation file from Step 1 bootable installation USB drive
worked for me, hope that helps!
Score 7
1 Opmerking:
This worked for me! I had the same issue, 2013 macbook failed to boot to internal HD after coffee accident. I could not execute step 3 (drive utility could not unmount disk). So I added step 1.5 above which is to partition the USB disk (using a working macbook) to create a 2nd volume (I called it mymacos) on the USB drive using drive utility, to Mac OS extended and GUID scheme. Then boot to macos recovery (step 2). My step 3 is to use the disk utility to erase/partition the second volume (mymacos) to APFS, leaving the bootable volume containing the new 8 gb OS install file untouched (in my case I used Catalina). Then step 4 is exit utility, click on macos install, and install to mymacos volume.
door
Aha, OK. After some sleuthing it looks like you are kinda stuck now.
I just tried to replicate the same situation you have here, and I got the same results. I attempted install Mojave on a SSHD I had laying around, booted from it externally on my 2012 MBP perfectly, but when I tried an internal boot on the same machine it threw a giant hissy fit and gave me that error you stated.
That is one big fat L for the average Joe, and a giant nail in the coffin for Mac Laptops 2012 and earlier. Unfortunate!
You are not alone!
Score 2
9 opmerkingen:
You need to redo your test. This time install a standard HDD or SSD into the system and then install the OS so the system gets the EFI update.
I'm thinking the Seagate SSHD cache is getting in the way here. Once you have a working system then add in the SSHD.
door
@danj I re-did the test with a both a HDD and a SSD, I got the same issue on both those.
door
So you put in a standard HD into your MacBook Pro 2012 system. Then using a OS installer boot drive did a reformat of the drive and install of the OS?
I have a SSD in mine and it's working! Its still running the Beta release.
door
@danj It runs on an external but it does not run internal.
door
4 commentaren meer tonen
I solved this, was super easy. Partition as GUID with one smaller partition I did 1GB to overkill as MSDOS (FAT) labeled it EFI. The second partition APFS. Voila all the modern ones will install. The confusing thing is that Apple calls the EFI partition a firmware parititon. I guess this is because if you use apple partition format and APFS the hardware cannot find a boot partition. So with the newer OS you have to create two partitions. You can do it all from Disk Utility on a USB installer or from macOS on a second drive. Everyone is just so frustrated because Apple hasn't helped find the solution but I was happy when it turned out to be so simple. Hope that helps someone else.
Score 2
2 opmerkingen:
Thanks. This is a clean and simple explanation. It worked perfectly !!
door
I have macOS Sierra installed on an external SSD (no internal drive). My SSD is formatted as Mac OS Extended (Journaled). I wanted to upgrade to Catalina but it just tells me, “You may not install this volume because the computer is missing a firmware partition.” So is that just because my drive isn't formatted as APFS? It doesn't show that format when I go to erase the disk. If I put the drive on my newer iMac and formatted it as APFS, would it let me install Catalina?
door
Voeg je antwoord toe
mayer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 91
Altijd: 83,481
