iPhone not charging after housing change.
I changed the housing of my iPhone and now it doesn’t charge, even the haptic feedback on the home button is not working.
Is dit een goede vraag?
Changing the housing is a very involved repair and a lot of things can go wrong during the process. Start by doubles checking the condition of all the connectors and flexes. Look for damage or tears and also look at the area surrounding the connectors are there are lots fo tiny electronics components that can be easily dislodged.
If you can’t see anything obviously wrong, connect just the Lightning Flex and Battery and connect it to an iTunes enabled computer. If the board is booting then iTunes will see it. If it isn’t recognized, you may have a logic board issue.
Then add one component (camera, button, sensor, screen) at a time until you find something that doesn’t work. Always remember to disconnect the battery first.
Was dit antwoord nuttig?
im sure did something wrong to the board before touch any screw u mouse shut the phone down then disconnect battery then left out the mother board put under microscope then post the picture if your not so good at fixing plz dont even open the first tow screw of the phone get it to technican
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 167
