two broken 30-inch cinema displays hoping to make one working
Hi,
I have one with short-short-long blink issue (display 1)and one with blank display (display 2)but the led is not blinking (continuously on).
how would you move on to make them into one working 30-inch Cinema Display?
display 1 shows an image when doing the flashlight trick against the screen.
display 2 doesn’t
thanks for your advise
Is dit een goede vraag?
5 opmerkingen
@mayer This might be a good one for you sir.
door [deleted]
What are the Axxx numbers from the bottom of the stands? It may look like A1407.
door mayer
A1083 on both displays (30 inch)
door Perry zelck
Apple Cinema Display 30-Inch (Aluminum) Specs
Identifiers: Aluminum - M9179LL/A - A1083
door mayer
solved : I took the inverter board form the display with continuous led (no blinking led) and put it in the display with short-short-long and works perfectly now
door Perry zelck
