Ga door naar hoofdinhoud
0xc000021a Error Code after trying Windows Reset Option
The owner wanted the tablet to be factory reset. Tablet has Windows 8 on it. After getting it to the options to do a Refresh or Reset, I selected the Refresh option. It all ran well and then it reboot. After it reboot and loaded a little bit, it showed a BSOD with the error code 0xc000021a. It will loop that error. It will attempt to do a start up repair but it will fail. I tried doing a sfc/scannow on the command prompt option on the page with other tools to try and at 26% it stops and shows that it can’t be finished. I tried doing the reset option and the same thing happens. Since it’s a tablet that I never heard of and their support apparently doesn’t know of the tablet that they sell, I’m at a bit of a lost. Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hello,
Blue screen of death which shows the error code 0xc000021a on the screen. This error says that your Tablet ran in to a problem needs to restart . Okay but you are saying that you have done all process like boot and restart then Firstly these issue appearing with a two files.
  • Winlogon.exe
  • Csrss.exe
These both files handle your log on an off process and Operating system files. It can be very scary when you are expiring this BSOD error 0xc000021a and your machine will not boot to the desktop. I know you had done many method but try this method for your issue .
Firstly Fix your corrupted files :
  • On your screen click on Troubleshoot.
  • Next click on “Advance option”
  • After that command prompt.
  • Now type the command in command prompt window
  • Type chkdsk C: /f /r this command check your System.
  • If your screen show the y/n then type y and hit enter.
Now reboot your System hopefully it will boot know correctly. If your error still persist then you should try another method for ''error 0xc000021a'' .
Was dit antwoord nuttig?
Voeg je antwoord toe
Carlos Ramirez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 344
