Ga door naar hoofdinhoud
Android smartphone from Asus. Features a 5.2" 720p display and is powered by a Quad-core 64-bit MediaTek processor with 2GB or 3GB of LPDDR3 RAM.
low temperature of battery and its not charging
low battery temperature not charging
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I think you will be needing a replacement battery. I found a battery replacement on eBay but i cannot guarantee that it will work.
Replacement battery
Guide for replacing the battery (Follow Step 1 thru 3 to replace the battery and follow them in reverse to re-assemble)
Was dit antwoord nuttig?
Score 1
The smartphone charging circuit has a battery temperature detection and does not charge when the temperature is too low. The battery temperature is too low, indicating that the ambient temperature of the mobile phone is too low, and it is necessary to go to a warmer environment to complete the charging.
Score 1
Voeg je antwoord toe
neilmarkandes28 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,207
