Ga door naar hoofdinhoud
Budget notebook laptop made by the Toshiba Corporation and released on January 17, 2010 tailored toward college students.
5 Vragen Bekijk alle
Laptop won’t turn on
I have a Toshiba satellite l505d, at first when I hit power button lights and fan turn but not screen no boot up, I tried a few times and it will start, but no metter how manny times I tried it don’t don’t start
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Does the disc drive start moving with a disc in it? If it stays powered with the fan on I doubt its anything to do with the power supply. It could be a loose LCD flex cable, laptops tend to have LCD connection problems after years of use. Try connecting it to another monitor with a VGA cable if it has a VGA output to project to another screen. If that works then its the LCD or the flex connection. If not then it could be a fatal motherboard issue.
Was dit antwoord nuttig?
sometimes they overheat, I have inspected some and they have heat marks
Voeg je antwoord toe
Fernando ullola zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 329
