Ga door naar hoofdinhoud
The HTC U11 Life is an Android smartphone that includes models HTC U11 Life (32GB NA), HTC U11 Life (32 GB), and HTC U11 Life (64 GB). The HTC U11 Life was released in December 2017.
13 Vragen Bekijk alle
Battery replacement for HTC U11 Life
Hello,
I need a Battery replacement for the HTC U11 Life. However, I can’t find it anywhere.
Does anybody know where to find a battery replacement for this device?
If I can’t find a battery replacement, is there a way to start the device without the battery to recover the data?
Thanks,
Alex
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This is a unibody device with an internal battery that cannot be removed.
https://support.t-mobile.com/docs/DOC-36...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Is there a way to start the device without the battery when it is connected to a computer?
door
I'd plug it in to the computer let it sit for an hour and then open iTunes and see if you can sync it one last time.
door
maybe you can try this one. I can see they sell on Amazon too.
Score 1
1 Opmerking:
This battery worked for me - X-Longer, Model CS-HTU110SL, Capacity 2500mAh, Lithium Polymer, 3.85 V DC, Part # B2Q3F100.
door
Voeg je antwoord toe
Alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 2,033
