Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Is my LCD screen broken?
Today I was replacing the digitizer on my iPad. In the process, the LCD screen fell on my feet; it was a soft drop and I didn’t think it would be an issue. I have replaced the digitizer, but now my screen looks like this.
Can you tell with confidence that this is the LCD screen itself, or the connector? I am looking for used LCD screens on eBay in the meantime.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s most likely the LCD.
If the LCD panel was damaged or if the flex/connector embedded in the panel is damaged, then you will need to replace it. If it was still connected to the logic board when it fell, then inspect the connector on the logic board to be certain.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
That's what I was thinking; thank you very much! Got a used part for 25 bucks. I will see if it does it.
door
Voeg je antwoord toe
Cagri Sahan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 265
