Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1053 Vragen Bekijk alle
I saw the connector of battery on iPhone se and 6 and 6s are the same!
So I have a question that if it is possible to replace 6s plus battery to iphone se?
I saw an article that the connector on iphone se is the same with iphone 6,6s,6s plus, even 7 and 7plus too.
and someone tested if they are compatible to each other, and it worked.
If it’s true, se users can replace battery with 6s plus or 7 battery then it can be used better battery capacity? if iPhone se has 6s or 7’s battery?
Thanks mates!
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Well, the iPhone SE has the smallest footprint of all those devices so you won’t be able to physically fit anyone of those batteries inside the SE housing. But yes, you can connect them when the phone is opened up and techs do this for testing all the time.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
To be clear, as per OP's photo, SE and 6S/6+/6S+ are compatible BUT NOT IPHONE 6 (called 6G in the photo). I learned this the hard way just now when I took out my SE battery to troubleshoot my wife's iPhone 6, and could not connect them...
door
If I connect iphone 6s plus on my iphone se. Will battery timing increase ? ?
door
It will connect, but physically it would not fit in the phone. And i am unsure if the phone would power up with it connected.
Score 1
1 Opmerking:
Just trim the battery. Use a scissors. I tried it and it worked perfect.
door
Will a battery out of a iPhone 7 fes or a iPhone set a iPhone
I have a spare iPhone SE battery, is it possible to use it on a 6s?
2 opmerkingen:
Did you figure out?
door
Did you get an answer for this
door
I tried this out and it works the iphone SE 1 gen battary works on the iphone 6s and fully functional and the battary health would be the same as if you got it brand new test it out even and it will work for you
Voeg je antwoord toe
Mango zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 74
Altijd: 10,704
