Ga door naar hoofdinhoud
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
103 Vragen Bekijk alle
JBL red light, and is not turning on!
Hello!
after using the JBL for 7 hours, it stopped working and turned on a flashing red led on the bottom of the box! I can’t turn on and i can’t turn off! it only turn off when the battery runs out, and when I put it to charge it does not turn on and continues with the red led lit on the bottom! Anybody know? thank you!
Is dit een goede vraag?
Score 3
2 opmerkingen
I fixed the issue on my Extreme2 but holding the power and volume + buttons down at the same time until I heard a response. The response I got was the same sound you hear when you are trying to raise the volume and are already at top end….. I powered down the unit and when I turned it on problem solved….. I had read various accounts/remedies online as well and was grasping at straws when I got this routine to work for me….
door
well, i changed the battery pack, 2yo. thinking probable cause
my unit powers up, plays for 5 seconds then i get a red blinking light an it powers off.
tried all the fixes quoted here
any ideas as to what next would be appreciated. thx
4 minutes ago by matthewroche
door
Voeg een opmerking toe
7 Antwoorden
Het nuttigste antwoord
Hello!
Did you solve it? I have The same problem
Thank you.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
My jbl flip 5 has all of the lights on and i tried to factory reset it but it’s not working i’ve tried turning it off and still won’t work
door
Hold and press power button for 20 sec
Score 2
1 Opmerking:
I did that but still won't go off
door
I have similar issue flashing red wont turn on or off but no power won't charge is this broken please
Score 1
1 Opmerking:
did you ever fix your problem?
door
I have an Xtreme 2 and this happened to me while attempting to activate “low frequency mode". However my speaker was plugged into the wall when it happened, I simply just unplugged it and plugged it back in and it turned back on. Try plugging it in if it wasn't already plugged in.
dude i have same on charge 3 i wanted to charge that bad boy when he was on 2 line and i checked after 2 h and still 3 rd indicator was blinking then unpluged and continiued same i drained battery with phone charger and red shows up after dying gets little energy with charger and continiues red blinking after unplug too i think charging board or some $@$* like that bro im confused mine is not that old yet 2 months only :/
if u get something tell me too
1 Opmerking:
I also have this problem with my jbl xtreme speaker. It has only been played maybe 40 times for a few hours in 2 years!
door
has anyone solved this issue yet? I have the same problem.
My JBL boom box 2 has a with and red and white light after attempting to put it in low frequency mode and now it won’t turn on or off
Voeg je antwoord toe
Raphael Morishita zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 155
Altijd: 16,966
