Ga door naar hoofdinhoud
Repair guides and support for top and front loading Whirlpool brand washers.
Why is my washer getting stuck on the rinse cycle?
I have a Whirlpool washer model number WTW4816FW and when I try to do a cycle it will wash, but when it finishes the rinse cycle it starts rinsing all over again. I have been canceling my current wash and then restarting with a rinse and spin and it works fine. How do I fix it to where it will rinse in a normal wash without getting stuck on repeat?
Is dit een goede vraag?
Score 2
3 opmerkingen
When I plug it back in, the locked light turns red for a couple seconds then goes off and there is a ticking noise every 5 seconds or so
door
Mine won't turn on all lights with done. Itll get to wash, rince, and spin nd that's it…
door
I follow instructions but the lock lid was lit up and lid would not open
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
Place the cycle knob on "Normal". Then turn one complete to to the left.
Then three clicks to the right.
Then one click to the left.
Then one click to the right.
Now all the lights will begin to flash.
Now turn to the right until the "Wash, Rinse, Complete" lights are all lit.
Press the Start button.
Unplug the washer from the wall for "10 seconds".
Plug it back in.
No Lights = Fixed.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
I did the full turn and got the Wash, rinse, done lights to light up.
door
For me, the reset procedure above worked for 1 load, then the same problem again: the rinse cycle repeated itself.
door
On my daughter's washer the capacitor came loose and broke a wire. The spin cycle would swing the capacitor around until the wire broke. It wouldn't complete the rinse cycle. Once the wire was repaired and the capacitor secured, it worked fine.
door
I have a maytag top load washer that is somewhat new no older then 4 years Proximally anyway have already had to put a new Agitator in it and now it washes through the fill and wash cycle and spins however when it goes into fill and rinse it stops completely the lid is locked for awhile maybe couple minutes but stops and then the rinse light blinks...have checked multiple things but at a completely blank for cause Can anyone help?FYI a new memory board for my washer from factory over$500.00!
door
@melissamcn35208
What is the model number of the washer?
door
Your machine having problem with heavy load. Reduce he weight/ load, so that it will procees.
Score 1
2 opmerkingen:
I really don't think it's a heavy load. I only have 4 small things in there, and they're not unbalanced.
door
Yep. Always make sure You have the correct weight and All the clothes should be well adjusted. So that load will be equal throughout the drum.
door
Hold down the start button for 3 seconds to reset.
My was doing the same this to fix it I plied I in opened the lin moved the drop to the left all the way around . The is stop then started back at it . The I push the tub down did the rest know thing while push the drum down . And the I opened and closed the lid 6 time and now it back to working ..
My whirlpool washer stopped at rinse cycle turning knob on spin cycle then start again
replaced drain pump and control panel - still sticks in rinse
1 Opmerking:
Hi @rafaelquino4016
door
Voeg je antwoord toe
Samantha zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 293
Altijd: 51,487
