Ga door naar hoofdinhoud
Mac Data Recovey software Bootable
Any data bootable data recovery software for backup in case of OS corruption (like Hiren’s BootCD on Windows).
Is there are any software on Mac environment software like disk drill , paragon on Mac based still not tested that can be used to test different Apple MacBook or iMac with out installing on each machines.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Apple does a good job here you have on the newer systems the hidden recovery partition on the systems drive. Even if you loose the drive you have the internet recovery option all built-in! To save time you can also create bootable OS installer drives (I’ve got about ten now). These are nothing more than a USB thumb drive already setup (see below).
As for your personal data and your apps you have built-in TimeMachine! This app allows you to setup a external drive as your backup drive to automagically back up (if you set it up to do this). If you have multiple systems you can even setup a system as your TimeMachine server so the drives on it are used at the backup server. I have a Mac Mini setup as my media server and is my backup server as well. That way my three systems are backed up.
Beyond that gets into tools used to fix drive issues like Drive Genius and antivirus and malware apps.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rajeev zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 159
