Ga door naar hoofdinhoud
Any tear down or repair guide for the Zenfone V (not 5)?
Has anyone encountered work with this phone? It is an Asus Zenfone V (not 5). Model A006. It is a Verizon only phone and was hoping to find out how to get in it to replace a broken screen. I have the replacement screen, just no info on how to repair. Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ok I finally went in blind. Heated the back and removed the glass. Everything else was visible and easy to repair at that point.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Can you make a tear down?
door
Hi did the zenfone V also have a fingerprint sensor that I need to be careful for when removing the back glass? I am assuming this would be the same as a Zenfone 3-5 correct?
door
Voeg je antwoord toe
Erika Cuellar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,635
