Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Vragen Bekijk alle
When I plug in my 3ds, the charger light goes on, but no power up.
So, I bought a 3DS for $20 from a thrift shop and they said it doesn’t charge. I opened the battery door and the battery has swelled up. But i thought I could power the system up without the charger…. but it doesn’t turn on. The charger port is also fiddely and I have to hold the charger in a weird way for it to charge. Could I need a new battery and charger port? Or is the whole thing busted and I wasted $20?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You could try and fit a new battery first to rule that out, seeing as it would be the cheaper option. This is because most likely unless you’re great at multi-pin desoldering, you’re gonna have to replace the entire motherboard / pcb.
But for £24.24 ($31.25) you can buy a new / used board that’s been dismantled from a previous 3DS.
https://www.aliexpress.com/item/Original...
Was dit antwoord nuttig?
1 Opmerking:
So I tried a new battery and that had no difference. I took apart the whole thing and 5 of the 6 pins of the charger port had broken, so I resoldered them and now it works good as new.
door
Voeg je antwoord toe
Hyrum Tripp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 66
