Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Power/Sleep Button being weird
Partial function with the power/sleep button. When I hold the button down long enough to turn off the phone it turns off just as it’s supposed to. But when I press it to put the phone to sleep it rarely works and the phone stays awake.
Am I likely going to need a new cable assembly? Thanks,
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Have you recently disconnected the battery to do some other repair? A 5s power button will behave like this if the phone has lost it’s correct date/time after battery disconnect.
Was dit antwoord nuttig?
Score 1
12 opmerkingen:
Yes, I have disconnected the battery for a repair. I have reset the date and time, though. Is there a fix that you know of? FYI; There is currently no SIM card in the phone as it's one of our back up phones. Not sure why this would matter, though.
door
The SIM card is part of how it will natively connect to cell service and update the time after a repair, otherwise you have to connect to iTunes.
Put a SIM in it and leave it for awhile or leave it connected to iTunes. The problem will resolve itself as soon as the phone is able to connect for a bit.
Next time you ask a question provide ALL recent repair history--this is a simple problem that most people are unaware of, and it was only by chance that i could recognize it without the history of "this happened after we fixed X"
door
Thank you Jessa, that's a good point and I'll remember it. I'm still kind of a newbie but I'm glad you asked the relevant question that led to the answer! I didn't at first associate the button malfunction with the repair as it had been awhile, albeit with very little actual use. Not enough to detect the button malfunction anyway and no time either connected to iTunes or with a SIM in place. It's so cool how much I'm learning from this site!
door
Well, that didn't solve the problem. It still won't go to sleep on command.
door
You can overlay a new power button without fully installing it to see if this is just a bad button. If the history is "we changed the battery" then the power flex runs under the battery and this then becomes MOST likely. If not, then it is unlikely but still possible. We still don't know the history of this device which makes it impossible to give good answers.
door
7 commentaren meer tonen
Voeg je antwoord toe
stevencbaldwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 144
