Ga door naar hoofdinhoud
Ondersteuning voor golf buggy's op gas of elektriciteit, ook wel golfkarretjes of handicarts genoemd.
494 Vragen Bekijk alle
Golf Cart Charging Question
So..I have a 2001 Club Car DS 48v cart. It seems to charge normally meaning the charger runs and shuts off when batteries are seemingly fully charged as I see that over the course of the charge the meter creeps toward 0. However, I will come back later and see that the charger has kicked back on. I guess my question is: Is this cycle of charger off and on “normal” behavior or should I be checking for a current draw or short somewhere?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Are you getting the normal hours of run time out of the cart? If so, the charger is doing ok. If run time has become shorter, suspect a bad battery or more and do appropriate charge-and-load cycles on your batteries. Note that batteries have to be disconnected from their 24- or 48- volt setup in the cart to test each one correctly.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
mjopa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 38
