Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een hoogwaardige, geavanceerde compactcamera geproduceerd door Canon.
lens error for canon powershot sx60 hs
Hi! I couldn’t find the option for the Powershot SX60 HS, but when I try to turn it on, it gives me the message ‘Lens Error, Will Shut Down Automatically, Restart Camera.’ I restarted it but it gives me the same messsage. Help? I’ve tried inserting the battery in and out, to no avail.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Unfortunately the lens contains several motors and sensors and any electrical or mechanical fault with any of them will generally just give this “lens error”. Your best bet is probably to look out for another on eBay adverstised as “spares or repair” and with some other fault. It generally isn’t that hard to make one good camera out of two duds!
Was dit antwoord nuttig?
Score 1
You need lens cleaning. Take it to camera repair shop
Score 1
3 opmerkingen:
Lens error.
Will shut down automatically
Restart camera
This is what appear.
What I can do ?
HELP PLEASE
door Deel
L'obiettivo non ha nessun movimento quando accendo la camera. È dentro ma bloccato in apertura. Aiutatemi. Vivo all'estero dove non c'è assistenza
door Deel
In my case was a fatal error. The shutter was damage forever. Two cameras SX60 and two disappointment. Worst Canon camera ever made.
door Deel
Voeg je antwoord toe
Arielle Clarke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 3,098
