LG Fridge lfxs30766s not cooling after coil cleaning
I have the lfxs30766s model and the freezer and fridge are not cooling. I have unplugged and plugged the unit back in with 33F temp for fridge and -4F temp for Freezer with the Ice Plus ON as recommended by LG and it didn’t work. I have already cleaned the coils. My fridge has a solid state relay (I believe) with an overload capacitor. Capacitor seems OK. I checked the large CAP on the PCB and it’s OK. I removed CON201, verified the voltage the got up to 200VAC, pressed the test button, heard several beeps, but no LED. I then plugged back in the CON201 and restarted the unit and did not see any LEDs. I hear the compressor kicking on and the fan starts. I left the fridge powered overnight and this morning it was still warm in the fridge and freezer. What can I check next?
Is dit een goede vraag?
1 Opmerking
you can check the compressor for continuity at the 3 pins on the left side of the compressor.
door rayjayster
